Mounting PP2+ upside down?
I am building a new flatboard style pedalboard. In the configuration I want, I wouldn't be able to access the power in on the PP2+ because of a pedal riser in the way. If I flip it upside down, it would work. Will flipping it upside down affect anything on the supply or make the board noisy?
Re: Mounting PP2+ upside down?
It's fine and will not cause any problems.
Go ahead... mount it upside-down.
I've been using mine for a couple months at a 90 degree angle and it's fine, so I guess that putting it upside down will be okay!
Yes, mount it in whatever is the desired orientation, that's fine... Every Which Way But Loose
