midi "Multi"
midi "Multi"
hello, on the control switcher there is a midi input called MULTI ... what is it for, from the manual I did not understand very well. Thank you
Re: midi "Multi"
The MULTI jack is not MIDI it just uses the same 5 Pin DIN jack type. The MULTI jack is the four make-or-break switches referenced to a common ground for use with a cable (usually custom made) that interfaces to an amplifier's footswitch jack when the individual 1/4" jacks cannot be used.
We can make cables to use the MULTI jack to connect to many different amplifiers... What amp are you looking to use with the Control Switcher?
![Image](https://i.ibb.co/kBDjjhH/avatar-sig-green.jpg)
