PX-8 Plus actual dimensions for planning pedalboard
Bakis
Post by Bakis »
Greetings from Greece! =)
Just a few weeks ago I discovered the existence of PX-8 Plus. Its functionality and features are exactly what I need for my board. Although there are 2 pedals (tremolo and fuzz) missing so far from my posession (that you see at the plan beneath), this will be my "final" rig.
I have measured everything in order to achieve the best possible result.
The only thing that I don't know, is the actual depth of the PX-8 plus, including the send/return jacks "height".
For instance, if the chassis is 75mm, then the total depth might be 80mm.
Ok, I understand that this sounds really picky (and I'm sorry if I am wasting your time), but I am about to invest almost 400 Euros on a brilliant product, that I need to be sure that won't cause me any troubles in terms of space and layout.
pedalboard S.jpg (38.01 KiB) Viewed 4243 times
chriseskow
Re: PX-8 Plus actual dimensions for planning pedalboard
Post by chriseskow »
The depth of the PX-8 Plus chassis is 65mm and the jacks are 8mm tall, so total depth is 73mm.
Don't forget to factor in the size of your audio, power, and MIDI cable heads as well! ;)
-Chris
