i have a road king (v1) i want to change channel using my ground control with gcx but when i connect it i wont change channel
do i need special cable or normal is suppose do to (mono tip to tip ground to ground)?
is the road king normaly closed or open?
and i have my ground control setup as latch switching
thank dany
Mesa roadking external switching question?
Re: Mesa roadking external switching question?
Virtually all Mesa amplifiers use the same design for the external switching scenario, and the Road King (all versions) is no exception. If your Mesa amp has individual jacks labeled with single functions then you can rest assured that each function can be controlled using the Out/N.O. jack of a GCX loop set to Latching with a Mono cable. Mesa recommends using a Speaker Cable (or any side by side pair cable) for the external switching functions as the capacitance of an Instrument Cable (or any coaxial cable) can in some cases cause popping. There should be no other cable connected to any GCX loop used for amplifier function switching.
