adapter cable for Digitech Trio
Cables provided with my Pedal Power Plus 2 wont power Trio pedal.is there anything available?
Re: adapter cable for Digitech Trio
Here are the details, including, links to additional items which are required (but are not in included with your stock Pedal Power cables):
To power the Digitech Trio with Pedal Power 2 Plus, use a Current Doubler Adapter, part# PPAP in outputs 5 and 6, DIP switches set 9V (normal) and one of the all black (standard polarity) cables supplied.
Note... this will not work for the Trio+. If you have the Trio+ you can power it from the AC courtesy outlet and its power adapter.
