I use the GCP with the GCX and the G-Major2, and i'm using 4 presets/bank in order to get 8 instants access.
And i'll be ok to use switch 1-4 to get 144 presets.
My question is divided in two parts:
1- How to program the instant access with the GCP, GCX enabled in the expander and the G-Major2 ?
2- How to program the presets ?
thank you Bobsil
Programming instants access with GCP, GCX + G-MAJOR2
Re: Programming instants access with GCP, GCX + G-MAJOR2
Your questions are a little too general so first I must send you to the Ground Control Pro manual...
1. Check out the Instant Access section of the Ground Control Pro Manual under Setup Mode. Here you can see how to assign which GCX loops you may want to control as well as how to assign MIDI Continuous Controllers which will control effects blocks in the G-Major 2.
2. Check out the Edit Preset section of the Ground Control Pro manual. Here you will find how to assign the MIDI Program Changes that recall patches on your G-Major 2 as well as how to set which combination of GCX loops should be active with each preset.
Good luck!
Good luck!
