Hey I built a pedal board and am planning to mount the Mondo unit under it. How much space should I have from the back and side vents from the board? The back and sides are solid wood.
Mondo Vent Spacing
Re: Mondo Vent Spacing
Any amount of space (even none) from the back and side vents should be fine as your Pedal Power Mondo should not run so hot (only warm) as for this to become a problem.
FYI, the standard mounting brackets cover the vent slots too.
Mount as desired!
Mount as desired!
