Mondo extension ?
Mwmd85
Mondo extension ?
Post by Mwmd85 »
Would it be possible to hook up a walrus audio phoenix to the Mondo?
And another Mondo question is, on the left side the 4 9/12 volt plugs at 400MA, could I hook up four stymon pedals to that? Or can you only use two 9-volts at a time with those four plugs?
Re: Mondo extension ?
Post by Rez »
Yes, the Walrus Audio Phoenix could be powered from the Pedal Power Mondo AC courtesy outlet.
The Strymon pedals can be powered from the 9VDC 400mA outputs (but not from the paired 12VDC outputs... leave these empty).
