voodoolab 2 plus and external power supply
hi to everyone,i'm new to the forum.I got a question:in my pedalboard everything is powered by the 2 plus but i want to add the MXR M222 talk box which requires 1A at 18 v which the 2 plus can't provide ever with current/voltage doubling cables.Will powering it with it's own power supply while everything else is powered by the 2 plus add noise or hum in the signal? take into account that everything is connected to the same outlet in my room
Re: voodoolab 2 plus and external power supply
It's fine.
Simply power the MXR M222 Talkbox with its power adapter, it will not create any problems.
And, certainly its power adapter could be powered from the Pedal Power 2 Plus AC courtesy outlet (if that is desired).
