Clarification on the MONDO? Are they all 9V capable?
Turquoise
Post by Turquoise »
All this time, I have not been using all the outputs because I thought some were only 12v. The 4 on the left say
9V-12 9V-12 400ma
I've only been using the ones that have 9V above them. Are they all 9v?
And furthermore,
The ones that say 12V ACA, those are 9V 100MAh?
Re: Clarification on the MONDO? Are they all 9V capable?
Post by Rez »
The two left-side outputs labeled as 12V are... 12VDC (and should not be used to power 9V pedals).
Each of the right-side outputs (labeled 1-8) which has its DIP switch set to 9V (the normal/default setting) will be... 9VDC.
