PX-8 Plus with TC Electronic Plethora
TLANTA
Post by TLANTA »
Hi All,
Is it possible to use the PX-8 plus midi function to switch pedal boards on TC Electronic plethora using A B C D and banks changes? Thank you
Re: PX-8 Plus with TC Electronic Plethora
I've not found anything that documents what MIDI Messages the Plethora responds to. :oops:
But I can tell you that the PX-8 Plus will send MIDI Program Change messages 1-36 on MIDI Channel 1... maybe there is a manual with the Plethora that states the MIDI specs?
TLANTA
Post by TLANTA »
Thank you for your reply. I have actually changed my mind and get a Line6 HX Effects instead.
