Hi Guys,
New to the forum and upgrading from a PX-8 to dual GCX units and a GCP.
I was hoping someone might be able to quickly spot check my connections to make sure I've got this planned out properly.
I'd like to be able to switch/blend three amps using loops 1, 2, and 3 on GCX 1.
Any help would be greatly appreciated.
Thanks a lot
Dual GCX's + GCP Connection Check
- Attachments
- GCX 2 - Rear.png.jpg (35.25 KiB) Viewed 3492 times
Re: Dual GCX's + GCP Connection Check
GCX 1 Front
- Attachments
- GCX 1 - Front.png.jpg (12.85 KiB) Viewed 3485 times
GCX 1 Rear
- Attachments
- GCX 1 - Rear.png.jpg (34.7 KiB) Viewed 3485 times
Hi there,
Have you given your setup a go yet?
I can see a couple of things that are incorrect but you may have already found this out.
Your Strymons aren’t in the audio path and your ins and outs are you opposite way around.
If you need some more help, ask away
And some other stuff.
