Hello! I' m an happy GCX and GroundControl Pro owner. I always used my system with a G-Force and various stomp boxes.
I decided later to buy a JMP1.... I made the midi connections as the owner manual said, so GCX MIDI out to GForce MIDI in, GForce MIDI in to JMP-1 MIDI in.
Well, I'm not a very expert to configure the midi devices, but when I switched on all the system, I lost the midi control of the GForce and the JMP1 doesn't responde... Have I to configure something else from the GroundControl? No problems with the loops, but the MIDI configuration doesnt work. I retryed to remove the JMP1 and the Gforce still doesn't change the bank. But I can se the signal from the midi in led when I press something from the pedalboard.... Help please!!! thank you
GCX+GForce+JMP1 MIDI
Re: GCX+GForce+JMP1 MIDI
Solved with an Initial device of the GCP. I've lost all the banks but it w
has been necessary! Thanks anyway!
