Pedal Power 3 Plus with Line 6 DL4
pudakak
Post by pudakak »
I'm looking at ordering the Dingbat Large with the Pedal Power 3 Plus but can't find any info as to if the PP3+ can power the Line 6 DL4 just like the PP2. Any help here?
Re: Pedal Power 3 Plus with Line 6 DL4
Post by Rez »
Yes, the DL4 can be powered too.
To power the DL4 with Pedal Power 3 Plus, use the 12VDC high current capacity (500mA) output with a 2.1mm/2.5mm Reverse Polarity Barrel Cable, part# PPL6, PPL6-R
pudakak
Post by pudakak »
Thanks Rez!
Does the PP3+ come with a reverse polarity barrel cable like some of the other PP units or do I need to buy one separately?
Post by Rez »
At this time (early production) the 2.1mm/2.5mm Reverse Polarity Barrel Cable, part# PPL6, PPL6-R is still included but this is likely to change. In the near future, only standard type cables may be included and "specialty" cables (reverse polarity, doublers, splitters, etc.) will need to be purchased separately.
