Hello,
I have brackets and a mondo on shipping, for a pedal train terra.
Since they are shipped with auto drilling screws; do I have to use a drill before, or an electric screwdriver is enough?
If needed, what diameter is required for the drilling?
brackets and pedal train terra 42
Re: brackets and pedal train terra 42
If you are using ours (color is plain metal), the Voodoo Lab brackets for Pedaltrain, part# PT, these have self-drilling screws and pre-drilling is not necessary (a power screw driver is sufficient).
But, if yours are the ones from Pedaltrain (usually color is black), pre-drilling will (likely) be required.
Hi Rez,
Yes! it's your plain aluminium brackets for novo, terra..!
Glad to hear a screwdriver is enough.
Thank you very much for your answer
Finally got it!
A 4x4 and a mondo under the terra 42, side by side.
Power to the people!
