Hi Everyone,
I would like some help to figure out how to power in my Two Note Le Bass. It's a 12V and 500ma valve pre amp pedal. Is it possible to power it with the PP2+ and if yes how ?
Please find here some specs:
https://wiki.two-notes.com/doku.php?id= ... r_s_manual
Mean
Two Note Le Bass and PP2+
Re: Two Note Le Bass and PP2+
To power the Two Note Le Bass with Pedal Power 2 Plus, use a Current Doubler Adapter, part# PPAP in outputs 5 and 6, DIP switches set away from normal and with one of the all black (standard polarity) cables supplied.
Alternatively, you can power it from the AC courtesy outlet with its adapter/wall-wart
