Using wah and volume pedal with GCP
Would it be possible to control both my wah pedal and my volume pedal using the ground control pro without using up loop space in my GCX? Could I do this using the Pedal 1 and Pedal 2 inputs on the GCP?
Re: Using wah and volume pedal with GCP
One way to route these is shown in this diagram...
http://www.voodoolab.com/gcxdiagrams/05 ... tching.pdf
Note that the guitar signal goes to the volume pedal and the wah before running to the Guitar In on the GCX. You can route the wah and the volume pedal anywhere in your audio path you wished to really.
The Expression Pedal ports on the Ground Control are for converting pedal movement to MIDI for controlling effect parameters on a MIDI controlled device. Your wah would certainly not be connected here, but the volume pedal could be if you were wanting to use it to control parameters on an effect processor or other capable device.
