Pedal switcher 9VAC connector size?
shai-ann
Post by shai-ann »
Hi there- need another 9vac adapter in 240 volts for my second pedal switcher, and as the Voodoo Labs dealers in New Zealand can't won't supply an adapter on it's own ( switcher originally supplied with US adapter ), can I please find out the internal and external dimensions of the connector that plugs into the switcher, so i can try and purchase a suitable adapter elsewhere, as the centre pin is definitely not your standard size! Thanks, Dave
Re: Pedal switcher 9VAC connector size?
The power jack on the Pedal Switcher is a 2.5mm x 5.5mm Barrel connector, which is standard for low voltage AC use.
If you have trouble finding the correct thing feel free to contact info@voodoolab.com to get one of the power supplies we ship with export units.
