power positive and negative polarity pedals using MONDO
Can I safely power both positive and negative polarity pedals using the MONDO, thanks!
Re: power positive and negative polarity pedals using MONDO
Hi there,
You need to power the pedal with the correct polarity, normal is centre negative, if you have a centre positive pedal, you need the correct cable to suit or make your own or modify a normal cable.
Here’s a link to Voodoo’s cables
http://www.voodoolab.com/shop/index.php?cPath=22
Cheers
Cheers
And some other stuff.
Indeed and as suggested, it's fine but for each type, the proper polarity cable must be used.
Standard polarity (center negative):
2.1mm Standard Polarity Barrel Cable, part# PPBAR, PPBAR-R and PPBAR-RS
Or,
Reverse polarity (center positive):
2.1mm Reverse Polarity Barrel Cable, part# PPREV, PPREV-R
2.1mm/2.5mm Reverse Polarity Barrel Cable, part# PPL6, PPL6-R
Or,
