boBoss wl-50 wireless
Markus_B
Post by Markus_B »
I have the Boss wl-50 wireless transmitter and the Pedal Power 2+, I'm unsure if this can power the WL-50 as I've noticed the power fluctuates when using the 2plus and I have to unplug and plug it back in so it's abit of a hit and miss.
Do I need to combine ports 5 and 6 to give me 500mA or ports 4 and 5 to give me 350mA
Boss specs below.
WL-50 power consumption. Power consumption during wireless communication: 60 mA. Power consumption during transmitter charging: 320 mA.
Re: boBoss wl-50 wireless
Post by Rez »
If you are also powering it during charging (since 320mA is required), use a Current Doubler Adapter, part# PPAP in outputs 4 and 5 (or 6 and 7), DIP switches set normal (9VDC) with one of the all black (standard polarity) cables.
Hope this helps!
