IOS 5 -The 9/12v 400mA outputs.
Can I use both, the 9v400mA and the 12v400mA on my ISO5 power supply? 12v to power an X4 power extention and the 9v to power a Digitech Mosaic pedal. The pedal uses a 9v400mA power supply.
Re: IOS 5 -The 9/12v 400mA outputs.
Yes but since the Mosaic is a high current pedal, there will not be much current remaining for the other pedals (ie. only 400mA total for the Mosaic and X4 outputs combined).
Also, you might power the Mosaic from on of the X4 outputs and low current 9V pedals from the other outputs (including the 9V from the 9/12V ISO-5 paired outputs).
