H9 power cutting out from PP3+
LloydEmAll
Post by LloydEmAll »
Greetings!
I'm having an issue where my H9 is intermittently losing power from my pedal power 3+. This doesn't happen when I have it plugged in to the recommended Eventide power supply. With the PP3+, I'm using the black-to-red cable with the red end in the H9, and I'm even using a current doubler from two of the 500mA 9VDC outputs so in theory it's receiving 1000mA of juice which should be more than enough.
Could the entire PP3+ unit may be past its limit? Here's the list of what it's powering:
- Eventide H9: 500mA (9VDC)
- Empress ZOIA: 300mA
- Strymon Timeline: 300mA
- Strymon Nightsky: 300mA
- Strymon Deco v2: 300mA
- Strymon Sunset: 250mA
- RJM MEGX: 200mA
- Fairfield Accountant: negligible
- Boss TU-3: 55mA
Total: ~2.2A
Would this be an issue? Am I better off powering the H9 out of the 12v output instead?
Any guidance or suggestions would be greatly appreciated!
Many thanks,
Lloyd
Re: H9 power cutting out from PP3+
Post by Rez »
Thank you for also emailing us at: info@voodoolab.com.
If you need additional assistance please let us know.
