Hey, I've been thinking of buying a Voodoo Lab Pedal Power 2+ because I've only heard good things about it and it's the only powersupply I can find that can help run my DigiTech Whammy IV.
Also I need a pedalboard, and I see the PedalTrain boards are made with space to mount the PP2+.
My question being: Is there room for the whammy's AC adaptor when the powersupply is mounted to one of those boards?
PedalTrain + PP2+ + AC Adaptor?
Re: PedalTrain + PP2+ + AC Adaptor?
Excellent choice of power supply!zinknissen wrote:My question being: Is there room for the whammy's AC adaptor when the powersupply is mounted to one of those boards?
You can't really plug in wall warts directly into the courtesy outlet of the PP2+ when it's mounted with brackets on a PedalTrain. You'll have to get a small extension cord to bring power out through factory-cut circular hole. Hope that helps!
