Expression pedal options
arizona guitarist
Post by arizona guitarist »
So why does the Ground Control allow you to pick the various functions of your expression pedal? I mean, why should I pick Pitch Bend on the unit when I still have to program my G Major 2 to use that pedal for pitch shifting, volume, time, etc?
Re: Expression pedal options
Pitch Bend as a setting within the Ground Control Pro is specifically for remotely controlling the pitch wheel on keyboards.
If you are controlling various effect parameters on a G-Major 2, you will assign individual Control change numbers for the Expression Pedal within each Ground Control Pro preset. I hope that helps.
