Hey there!
Can I switch the channels on an Engl Fireball (original 60) directly from the gcx/gcp? For your info, the head has one jack out for the footswitch. A on or off = ch1 or ch2 and B on or off = master vol a or master vol b.
Thanks in advance!
Engl Fireball question
Re: Engl Fireball question
You would need an Insert Point cable with the Stereo end connected to the amplifier's footswitch jack and the mono ends each connected to the Out of a GCX loop. One GCX Loop will A/B the channels and the other GCX Loop will A/B the master volume settings. Good Luck!
Thanks Mr. Clark!
