Does anybody have experience using the courtesy outlet on the PP2+ in the UK / England? If so, can anyone advise exactly what kind of cable I need to connect to the outlet to allow use of a power strip?
Simon
Using the Courtesy Outlet on the PP2+ in the UK
Re: Using the Courtesy Outlet on the PP2+ in the UK
The connector used for the Courtesy Outlet on the export Pedal Power 2+ in known as a Reverse IEC. Check with the folks at Sounds Great or likely any dealer that sells rack power conditioners. Good Luck!
Maplin sell the correct cables for that mate.
Does the PP2+ have enough power to supply an extension and subsequent appliances ?
