Hi there,
can I control via MIDI the presets of a Roland GR-20 using a Vodoo lab Ground Control???
Ground Control and GR-20
Re: Ground Control and GR-20
I have a GR-33 and the GCP controls it fine. I can change presets without a problem. You just need to get the two talking to each other and off you go. I am still working on changing expression parameters in the GR-33, but this also seems to be possible.
Thanx, I'm gonna try...
@DF400 Would you mind sharing your GR-33 set up? I have one too and I'm trying to figure out the best way to incorporate it into my rig. I'm using a GCX w/ GCP as well.
Any advice would be greatly appreciated.
The setup here would simply be to find the MIDI channel that the Roland device is set to respond to (Channel 1 is a usual default) and assign the same channel in the Device Name/Channel within Setup Mode on the Ground Control Pro. Once the MIDI channel is set, Ground Control Pro presets will recall patches using MIDI Program Change messages. Any Ground Control Pro preset can be edited to send the desired Program Change in order to recall the desired patch.
![Image](https://i.ibb.co/kBDjjhH/avatar-sig-green.jpg)
Thanks John,
That makes perfect sense. I'm probably overcomplicating things but what do you advise for the guitar signal? As a stand alone unit, the Roland synth pick-up carries the guitar signal through the synth unit and then to an amp. Would you recommend simply running the guitar line in front of the GCX or through one of the loops in the GCX?
Thanks again.
Thanks again.
What do you want to do with the guitar signal from the synth? If there is no other processing you want to do to the guitar signal then running it directly to the amp seems the best choice. If you have pedal effects that you want to switch in and out of the guitar signal path then running to the GCX would be the thing to do.
Totally helps and I guess it was a really a no brainer... I tend to over-complicate. ![Smile :-)](./images/smilies/icon_e_smile.gif)
Thanks for taking the time to write. Much appreciated.
