the rack set up
the rack set up
still trying to get te slight hum sorted out, i live i the Bahamas, so its not so easy just to send this out and have it checked and finished by a pro, however that is where i am at,....
- Attachments
- drawer 2
- 009.JPG (115.23 KiB) Viewed 3247 times
- drawer 1
- 008.JPG (137.92 KiB) Viewed 3247 times
- rack
- rack 001.JPG (121.31 KiB) Viewed 3247 times
Re: the rack set up
Dude... everybody knows that gear hums in the Bahamas. You can't have such fine rum and awesome weather AND gear that doesn't hum!
Re: the rack set up
Valid point!
Hum is gone, just have loop 8 issues, when engaged the volume drops off, and won't switch back occasionally, turn off a reset then it's fine.
Re: the rack set up
What do you have in GCX Loop 8? Do you get the same problem if you run a cable from GCX Loop 8 Send to GCX Loop 8 Return?
