Setting 0 to 10 on GC Pro
Is it possible when using the 10 presets on GC Pro to have the 0 as 10? Trying to set this channel on my Triaxis but the Triaxis does not recognise channel 0.
Re: Setting 0 to 10 on GC Pro
Every Ground Control Pro preset is programmable. Any preset can be programmed to send whatever Program Change number you want. Check the Assigning MIDI Program Changes section under Edit Preset within the Ground Control Pro manual for detailed instructions on how to program your presets so they recall the numbered patches you want.
Let us know if you run into any troubles. Good Luck!
John, thank you so much - it worked! Apologies for the noob question!
