line 6 dl4 and electro harmonix 16 second delay (reissue)
grahamstuart
Post by grahamstuart »
Hi there,
will my trusty pp2 power the following units:
line 6 dl4 - if so which outlet- mini switch in which position and which cables?
electro harmnix 16 sec delay reissue - which outlet, mini switch position, which cables?
graham
belleville ontario canada
Re: line 6 dl4 and electro harmonix 16 second delay (reissue
The DL4 can be powered from either of the "L6" outputs (output 5 or 6 with the corresponding DIP switch set away from Normal) using the supplied PPL6 cable with the single red end. An example of this is explained in the Pedal Power 2+ manual in the "Line6 Modeling Pedals" section.
The 16 Second Delay should be able to be powered from any Pedal Power 2+ output with the corresponding DIP switch set to Normal using the included 1/8" Mini Plug cable.
