Pedal Switcher
Neil C
Pedal Switcher
Post by Neil C »
Hi everyone,
I've seen in the rig pictures section someone (sorry, can't remember who - rubbish memory!!) has used a Pedal Switcher in a draw to add a couple of extra loops instead of having another GCX. How does this work?
I've used 8 loops on mine and could do with 3 more loops (not essential, but would be cool to do it). I would want to be able to control each of the new 3 individually as well as having them programmed in though so would the PS do this?
Also - what is the PP2 Versa? I use PP2 but haven't heard of the Verse or seen it anywhere other than the rig pictures.
Neil
Trueman
Re: Pedal Switcher
Post by Trueman »
Hi Neil the Pedal Switcher is liking having 1/2 GCX and setup in the same way another GCX would be - its all in the manual. It doesnt give you more instant access buttons - you still have a maximum of 8 on the GC Pro.
The Versa contains AC power and high current outputs to power pedals like the Digitech Whammy/Eventide Timefactor etc
Connoisseur of good tone.
http://www.guitarpedals.co.nz
