Running a Line 6 DL4 and an M5
jeztone
Post by jeztone »
My board is consists of 4 traditional 9 volt type pedals and a Blackstar HT Dual which is AC and has to use its own adaptor.
I also have 2 line 6 pedals a DL4 Delay Modeller and a new M5, is there any product that lets me run everything but the Blackstar on one universal supply?
Re: Running a Line 6 DL4 and an M5
Post by Rez »
No. But, you can get close with Pedal Power 2 Plus. You'll need to power the Blackstar and M5 from a power strip connected to the AC courtesy outlet.
Note: You can connect a power strip to the courtesy outlet for use with multiple pedals/effects and their adapters. It may also be used to power an additional Pedal Power 2 Plus, ISO-5 or Pedal Power AC. The courtesy outlet is NOT designed for use with power amplifiers or other high power equipment.
thuggyBear
Post by thuggyBear »
can you not run a M5 and a DL4 at the same time?
thuggyBear wrote:can you not run a M5 and a DL4 at the same time?
Not from the front outputs of the Pedal Power 2+. A Pedal Power Digital will power both at the same time with two more 400mA outputs to spare.
