Ground Control Pro CC/PC question
jimosity
Post by jimosity »
In 10 button mode, can the GCPro send both a PC *AND* CC change at the same time?
I don't want to use 4 button mode and then have a PC on one of the 4 buttons and then also step on a 1-8 instant access button.
Re: Ground Control Pro CC/PC question
There is currently no user definable CC message capability when in 10 Presets per Bank mode. You can enable a GCX that is not being used within the Ground Control Pro and use those CCs if the gear you are controlling is programmable for the CC message and can accept them on MIDI channel 16.
GCX-1 = CC 80-87
GCX-2 = CC 88-95
GCX-3 = CC 64-71
GCX-4 = CC 56-63
