Pedal Switcher any problems?
Hollywoody59
Post by Hollywoody59 »
Hi folks and voodoo lab user.
Today there is a question for the working of the 4 way pedalswitcher
Mine seems to steal minimal but noticeable soundcharacter???
Then it is not the real true bypass....???
I use named good orginal switchcraft plugs on my board, but I hear in the
pedalswitch loop ways less treble tones and more bass..???
It would be very kind if someone has the same problem or knows what I could do!!!
By the way there a lot of pedal loopswitchers today, which seemed to be more versatile!
Gigrig, One Control, Moen, they all have more than 4 loops.
When will Voodoo Lab built a new pedalswitcher with more features but less midi??
a 6way will be the best way or not???
Hollywoody
Re: Pedal Switcher any problems?
Are there any signs of damage to these jacks? These are typical 1/4" jacks and a 1/4" plug should not be able to fall out without at least some force applied.
Hollywoody59
Hi John Clark,
thank you for your statement. No the plugs I have use are normally
switchcraft cableplugs which are new (spectraflex cables, xotic patcher)
But the connection is in my opinion not tighten enough, because if you
touch a little the plugs they get out from the voodoos inserts.
Holly
