ok what is the difference in the voodoo lab gcx and the digital music corp gcx?
I myself don't know but i just want to know.
i have the digital music gcx and the voodoo lab gcp
here is a quick pic at the rack. it was my first build attempt
quick gcx question
quick gcx question
- Attachments
- rexrig.jpg (41.46 KiB) Viewed 6933 times
Wah
Whammy
PitchBlack
phase
flange
Delays OD
Jcm 800
Blackstar HT 50
5150 signature peavey & 50 watt 5153
http://www.myspace.pallor
http://www.myspace.com/falseflag7
Whammy
PitchBlack
phase
flange
Delays OD
Jcm 800
Blackstar HT 50
Re: quick gcx question
They are the same. My first GCX had the DMC label on it - my next one had the VoodooLab label...
science guy---thanks for the response!!!!! i feel a bit better thinking maybe i was losing out on something; what i don't know either way piece of mind.
thanks
again
thanks
again
Wah
Whammy
PitchBlack
phase
flange
Delays OD
Jcm 800
Blackstar HT 50
Whammy
PitchBlack
phase
flange
Delays OD
Jcm 800
Blackstar HT 50
That is not entirely accurate... The DMC is older and I believe does not (or at some versions) have a buffered input. The VL ones have a "guitar in" and a "feed thru in", and the guitar in is buffered. Or it could be that both inputs on the DMC version are buffered... In any case, not exactly the same. I have one VL and one DMC and they are different on the inputs.
Gear List:
'87/'88 Ibanez Sabre's (7), '86 Ibanez PL1770, Budda SuperDrive 18, George L's Cables, Barber Direct Drive (best $99 ever spent!), Rodenberg GAS-828, Nobels ODR-1, Morley Bad Horsie II, TC Electronic G-Major II, Ground Control Pro and GCX...
My GCX is a DMC with a buffered guitar in, and a feedthru in, same as the VL.
When you start the GCX, watch the direction the loop lights scroll, right to left is the newest firmware version. IIRC that would also be the newest hardware version as well, regardless of "brand".
Dom
Dom
mine has a feed-thru and a buffered. just wasn't sure of anything else.
thanks
thanks
Wah
Whammy
PitchBlack
phase
flange
Delays OD
Jcm 800
Blackstar HT 50
Whammy
PitchBlack
phase
flange
Delays OD
Jcm 800
Blackstar HT 50
