tap tempo
Bludrock
tap tempo
Post by Bludrock »
regarding controlling delays with the GCX and ground control: i have a t rex replica delay which has a midi in the as this pedal uses midi to control tap temp through cc messages. Can somone tell me how to hook this up so one of my buttons on the ground control can be assigned to control the t rex delay?
Trueman
Re: tap tempo
Post by Trueman »
I have a client wanting to do this as well. First need to figure out what CC# the Replica responds too. Should be easy to set up. What is your midi signal path? Are you running the midi cable straight from the Replica to the GC Pro or from the Replica to a GCX?
Connoisseur of good tone.
http://www.guitarpedals.co.nz
