Just wondering... Can the Pedal Power 2 Plus safely power a Shure PGX4 wireless receiver?
The power reqs for the PGX says 12-18Vdc at 150 mA. The PP2P would also be running a couple of distortion pedals, like a TS9 and an OCD.
Thanks...
Wireless recievers?
- Site Admin
Re: Wireless recievers?
This should be okay from outputs 5 or 6 with the DIP switch set away from normal.
**NOTE: Check the polarity on the power supply, this may be center positive! You need to verify this and then use a reverse polarity cable.
Because all Pedal Power 2+ outputs are isolated, you can power devices that require either polarity by using the correct cable.
Please post your results, thanks!
Regards,
Josh Fiden
Founder / CEO
Regards,
Josh Fiden
Founder / CEO
