How to do it?
dsaca
How to do it?
Post by dsaca »
Hy Guys!
I've got a question about GCX. I'm a new user and I try to design my rig.
I have a Triaxis and a JMP-1. I like to use them once with each other, once seperatly and I'm not sure that my idea is correct (I saw the example).
I attached a work Sheet and I like to ask is it correct to use them the way I wrote.
Thank you in advance!
My rig
My rig
Re: How to do it?
In that setup Loop 3 will be a strict A/B switch between the preamps. Loop 3 Off = Triaxis, Loop 3 on = JMP-1. In order to have them both active at the same time would require two GCX loops (one for each preamp) and the use of a mixer to properly combine the signals.
