Hi guys,
Has anyone experienced troubles on mounting the PP-4x4 underneath PT-JR usoing the supplied brackets since it's larger and taller than the PP2+?
Also, is it ok to mount it under the PT-JR as far as the ventilation is concerned? I suspect the PP-4x4 fan vents won't align with the courtesy outlet hole which might cause heating issues.
Many Thanks,
Mounting PP-4x4 on Pedaltrain JR
Re: Mounting PP-4x4 on Pedaltrain JR
The venting shouldn't have an issue as long as you're not driving it to the absolute max. Mounting it wherever it fits should be fine.
Julian Shur
