Hi, I got a problem with my Micro Pog. I'm using PP2+, feeding it with 5 or 6 output of the PP as told, black normal cable, switch to normal. The pedal work, but it seems to have veeery low sound output (the dry signal knob, supposed to be a buffer, barely get the bypass sound at maximum). The pedal it's new, and if I use it with his matched EHX adaptor it works fine and it has the right output volume.
How so?
Thank you very much for time and answers.
Micro Pog
Re: Micro Pog
That's very strange. Do both outputs 5 and 6 display the same issue? Do you perhaps have a current doubler cable you could use to combine 5 and 6 ?
Julian Shur
