I'm looking into purchasing the PPP2 and wanted to know if the following pedals work with it:
Electro-Harmonix Holy Grail Reverb
Electro-Harmonix Big Muff
Digitech Whammy
Line 6 MM4 Modulation Modeler
I'm using those along with the following:
Boss DD-20 Gigadelay
Boss OC-2 Octave
Boss Noise NS-2 Suppressor
Boss Chromatic Tuner
Ibanez Tube Screamer
Dunlop 535Q Crybaby Wah
If the top list does work with the PPP2, would I need 2 of them to run all together? Also, would the Pedal Switcher be able to recognize the 4 switches on the Line 6 MM4 or would it treat it as one pedal?
The Pedal Power 2+ can power all these pedals except for the Whammy. The Whammy requires AC power only. A Pedal Power AC could power the Whammy and the DL-4 as well as two Pedal Switchers, leaving the other eight pedals for the Pedal Power 2+.
There is no provision on the DL-4 to remotely control its switches.
