2 Nova Pedals, Micro Pog and PGX4 Wireless and PP2+
haroldnavarrete
Post by haroldnavarrete »
I currently have a Pedal Power 2 Plus that came with a pedalboard I bought online. I was wondering if I can power 2 Nova Pedals (Delay, Modulator), Micro Pog and PGX4 Wireless (12-18v 160mA)
Re: 2 Nova Pedals, Micro Pog and PGX4 Wireless and PP2+
With a Pedal Power 2+ you will need two Current Doubler Adapter cables. One connected to any two of outputs 1-4 with the corresponding DIP switches set away from Normal for the Shure PGX4, and another connected to any two outputs with the corresponding DIP switches set to Normal for the Micro POG. You can connect each of the Nova pedals to either output 5 or 6 with the corresponding DIP switch set away from Normal using the standard all black cables.
In this case I'd have to say that the Pedal Power Digital would probably be a better fit since it wouldn't require any adapter cables.
