I know I would have to make a little junction box to do this, but technically this should be possible.
Just wondering if there were any concerns from the Voodoo lab side?
Can I wire 3 pedal power 2+ outputs in series for 24v?
- Contact:
Custom Audio Amplifiers PT100
Bogner Ecstasy 101B
Carvin electric guitars
Bogner Ecstasy 101B
Re: Can I wire 3 pedal power 2+ outputs in series for 24v?
You can series connect as many outputs as you want. I do wonder why not use two 12V outputs though?
Also, three 9V outputs together will yield at least 27V. (Since the outputs are actually about 9.3V, on paper you would be just under 28V.)
