*URGENT* PP2+ Not Powering RC-30
Mhossey
Post by Mhossey »
Hi, I'm having a problem powering my RC-30. After reading through the manual I used port 5 and 6, and tried dip switch and normal, and away. No luck. For kicks I tried 1-4, and no dice as well. I've read a few threads about getting a Y doubler, but it seems like overkill. Not sure if I would need the voltage doubler, or current doubler.
I've also tried different barrel plugs; they power my other pedals fine, just not the RC-30. I don't have an actual boss adapter to verify the port on the pedal is still good. But it does work fine with batteries.
Any advice??
Michael
Re: *URGENT* PP2+ Not Powering RC-30
Not too sure what the problem would be here... the RC-30 should be completely fine to power from output 5 or 6 with the corresponding DIP switch set to Normal using one of the included standard all black Barrel cables. Common for Boss pedals would be that you also have to have a guitar cable connected to the Input jack before the pedal will power up.
Let us know what you find!
