I still have to replace a few of the colorful patch cables. I ran out of George L's right-angle plugs. I also need to solder up 2 custom MIDI cables using the Switchcraft Right-Angle plugs.
All of this (including the M9 and H9) are being powered by a PP-Mondo.
My custom pedalboard panel arrived yesterday. I'm using the Redco locking 1/4" pass-thru jacks. Still waiting for my MIDI pass-thru from Temple Audio.
Installed on my PT-3.
That's a Pedal Power MONDO on the right side.
New Pedalboard: PX-8, Mondo, Giggity & Sparkle Drive Mod
Re: New Pedalboard build with PX-8, Mondo and Sparkle Drive
nice rig!
where did you get the backplate and ¼ inch plug??
Pascal
Pascal
Marshall JVM 210H 100w
1960a cab with G12T75 and Vintage 30's
Fractal Audio AX8
Guitars:
IBANEZ JEM PMC
IBANEZ JEMjr Desert Yellow
EVH Wolfgang Vintage white
Fractal Audio AX8
Guitars:
IBANEZ JEM PMC
I designed the plate and had it fabricated.
The 1/4" pass-thru plugs are from Redco.
http://www.redco.com/Redco-PM-TRS-TRS.html
do you have one to sell?
Fractal Audio AX8
Guitars:
IBANEZ JEM PMC
Fractal Audio AX8
Guitars:
IBANEZ JEM PMC
Hey man! Really need your help, have you powered a line 6 m9 by using a voodoo lab 4x4 using the current double adapter? does it work?
I'm using a Mondo, but you should be able to do the same with the 4x4.Corygaff wrote:Hey man! Really need your help, have you powered a line 6 m9 by using a voodoo lab 4x4 using the current double adapter? does it work?
I use the current doubling cable connected to both 12Vdc 400mA outputs and it works GREAT with the M9.
http://www.voodoolab.com/shop/index.php ... hi8ed25qi3
Done. I finally got all of my Right-Angle MIDI plugs yesterday and finished wiring it up this morning. Labels on PX-8 show the actual signal path.
A couple changes since the last pics:
Giggity - makes a fantastic base tone on which to layer Fuzz boxes.
Tech 21 MIDI Mouse - Super-basic MIDI pedal to select presets on the PX-8, M9 and H9. One stomp and the entire board is reconfigured. The MM is phantom powered by the PX-8.
FF Mini (Silicon) - Great sound in a small package. This will will rotated out occasionally for my Tweak Fuzz.
Fender FWP-1 Wah - First in the signal path and basically a Crybaby, but with an internally switchable output buffer so it plays nice with my Fuzz Pedals. I've modded this to have a 6-way frequency range switch and toe frequency pot (similar to the Dunlop AIC wah). See pic below.
