I was hoping to run my new Eventide Pitchfactor off of my Pedal Power 2+ but it does not look like I can make use of the barrel outlets. Can the Pitcfactor walwart be plugged into the AC outlet on the Pedal Power 2+ ? It's input specs are 120VAC 60Hz 15W, output specs 9VDC 1200mA. Thank you.
Ryan
- Site Admin
Re: Eventide Pitchfactor
Hi Ryan,
No problem running the Pitchfactor adapter from the AC line out on the PP2+. Both the Pedal Power ISO-5 and the Pedal Power Versa will be able to run the Eventide pedals directly.
Josh Fiden
Founder / CEO
Josh Fiden
Founder / CEO
Wow, fast response! Thank you Josh!
Ryan
Ryan
