Getting 24 Volts AC from Pedalpower AC ?
analog guy
Post by analog guy »
Does anyone know if it's possible to get 24 Volts AC with Pedalpower AC , using a Y cable plugged into two PP AC 12 volts outputs ? (I'm planning to power Demeter Reverbulator Pedal)
I know you can do that trick to get 18 Volts DC from Pedalpower 2 (to power OCD at 18 volts) , just wondering if it works the same with PP AC ?
Thanks.
Re: Getting 24 Volts AC from Pedalpower AC ?
You cannot combine outputs for voltage doubling on the Pedal Power AC. for the Reverbulator you will have to use the supplied adapter connected to the Courtesy Outlet on the back of the Pedal Power.
