Voltage doubler and SAG outlets
ak47
Post by ak47 »
I have a voltage doubler cable I use with my PP2+ and as I have a drive pedal that operates from 9-18 volts, I am wondering if the voltage doubler will work ok from the two SAG outlets?
This way I can get the 18 volt headroom and if I want to, I can roll back the seperate outlet voltages to taste.
I think it should work in theory but I am unsure if using the voltage doubler from SAG outlets unevenly might cause trouble? I am thinking the overall voltage should be a+b but yeah.. Is it cool to do this and find a voltage sweet spot?
The pedal is a One Control strawberry red overdrive. Thx for your 'feedback' :mrgreen:
Re: Voltage doubler and SAG outlets
ak47 wrote:I have a voltage doubler cable I use with my PP2+ and as I have a drive pedal that operates from 9-18 volts, I am wondering if the voltage doubler will work ok from the two SAG outlets?
You got it! The "doubler" will simply combine the voltage of the two outputs used. No problem at all to use the two SAG outputs and dial the two voltages around.
ak47
Post by ak47 »
Awesome! Let the tweaking begin!
