GCX with Radial Headbone TS
Nova
Post by Nova »
So I just purchased the GCX Switcher and Ground Control. I have some setup questions hopefully someone could help me with.
I want to run a noise gate and tuner out in front.
Several effects in loops
A 5150 Head for dirty
A Vetta II for clean/fx
Basically am using 5150 for dirty and switching to the Vetta for different tones.
Also have a Headbone TS that allows me to run one cabinet.
I think I have most of it figured out but the Headbone confuses me. It does have a slingshot remote that allows me to control switching capabilities through a loop. But where do my inputs go? Since you have to connect the amp inputs through the pedal. How does that coincide with the GCX?
I basically need someone to help me set this whole thing up? anyone help?
Also does the ground control have the ability to change preset patches on the Vetta?
If anyone can make a diagram that would be awesome!!
Re: GCX with Radial Headbone TS
In this case the Out of the last GCX loop used for pedal effects would be your "guitar" feed into the Headbone. The Amp and cabinet connections would be as described in the Headbone manual. The Slingshot feature can be controlled by using either the Send or the Out of a single GCX loop.
Ground Control Pro presets will control the Vetta as well as the GCX simultaneously.
