Hello! I've not been able to find my answers so I'm coming straight to the source. Someone please advise me on which supply and cables I need to power this rig completely.
guitar- EHX 44800 Small Stone- Digitech Whammy 4- EHX Deluxe Electric Mistress- Boss LS2
> A) Boss SD1-Prunes and Custard- RV-3- DD-5- RE-20- VOX AC30
> B) Marshall Shredmaster- FENDER 85
** The EHX needs the 24V splitter cable and the EHX small stone uses a Walwart currently that has the old Pin Style insert. Please advise! Thanks So much
New to Voodoo- Need some advice from a Veteran
Re: New to Voodoo- Need some advice from a Veteran
I suppose I would go with the Pedal Power 2+ and use an output splitter, or the Pedal Power Mondo if you thought you might add more pedals later.
The Whammy 4 requires AC power only so it will have to be powered using its supplied adapter. This can be connected to the Courtesy Outlet.
The 24V Deluxe Electric Mistress can be powered from any two of outputs 1-4 (or any two 12V outputs) with the corresponding DIP switches set away from Normal using our optional EH24 2.5mm Voltage Doubling Cable.
All the rest of your pedals can each be powered from any output with the corresponding DIP switch set to Normal (any 9V Output). On a Pedal Power 2+ you could gang up a couple of these pedals using the optional Output Splitter Adapter connected to output 5 or 6 with the corresponding DIP switch set to Normal (high current 9V) and power the DD5 and RE-20 together. The LS-2 has a power outlet so using another standard Barrel Cable you could power the RV-3, the LS-2 power input would come from output 5 or 6 with the corresponding DIP switch set to Normal (high current 9V).
Included with the Pedal Power are enough standard barrel cables as well as the Mini Plug cable that fits the Small Stone.
![Image](https://i.ibb.co/kBDjjhH/avatar-sig-green.jpg)
